It is currently Sat Aug 09, 2025 7:34 am
 Post subject: True Channel Jig
PostPosted: Tue Aug 25, 2009 8:20 am
Last Name: Charnock
Country: UK
Hi - I am placing my first order with Stewart Mac and I am debating getting the True Channel Jig for routing edge binding. As a first time builder would you say this is the easiest method for me to use ?
 Post subject: Re: True Channel Jig
PostPosted: Tue Aug 25, 2009 8:30 am
I'm VERY happy with mine. It is a well designed system that makes it pretty hard to screw up. The column mounted router makes all the difference, no rocking, no off square cuts. [:Y:]
Gordo
PostPosted: Tue Aug 25, 2009 9:03 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I have used mine for 3 guitars so far and have no issues with it.
Fred
Fred Tellier
PostPosted: Tue Aug 25, 2009 12:50 pm
First name: Lars
Last Name: Stahl
City: Stockholm
Country: Sweden
Just a pointer, do also check with John Hall at BluesCreekGuitars, he also sell a similar version of the stewmac´s . If you want good advice , try calling him , he will get you on the right track right away. [:Y:]
Lars
PostPosted: Tue Aug 25, 2009 1:15 pm
First name: Jim
Last Name: Hansen
I have the stew mac jig and have had great success with it.
My only complaint isn't really with the jig, but the stewmac bearing set is a little on the light side in terms of selection. I found myself halfway in between sizes using their bearings too often. I ended up ponying up for the full set (two sets actually) of the LMI bearing sets.
Jim Hansen
PostPosted: Tue Aug 25, 2009 2:02 pm
With this jig you need to be aware that laminate trimmers do not all have the same mounting angle . This can make the channel off square .
PostPosted: Tue Aug 25, 2009 2:53 pm
Last Name: Charnock
Country: UK
I asked a question in am earlier post, its seems Bosch and Makita are compatible and I can get them in the UK
PostPosted: Tue Aug 25, 2009 3:04 pm
Re Bosch trimmer, I had to make a 1/4" Lexan adaptor plate to get my Bosch Colt trimmer to work. Took about 1/2 hour to make. Lexan plate with countersunk screws attaches to trimmer base casting, and with screwheads countersunk in the opposite direction it attaches to the levitating aluminum base on the vertical router column. Some other trimmers look like they would be a straight ahead bolt-up, but my Bosch baseplate screw holes did not line up with the pre-drilled holes in the jig, hence the adaptor plate.
Gordo
PostPosted: Tue Aug 25, 2009 3:19 pm
Last Name: Charnock
Country: UK
Stewart Mac use the Makita in the demo, since I don't think there is much in the laminate trimmers I may go for a Makita. I'll post a question on their website and feedback what they say.
PostPosted: Tue Aug 25, 2009 3:22 pm
First name: Mark
Last Name: Thorpe
City: Valparaiso
State: Indiana
I love mine. I use mine with a Freud FT750 Laminate Trimmer bolted right up.
Users browsing this forum: Bing [Bot] and 10 guests
